12:46 PM
- Mute
- Permalink
- Report
Greetings Everyone.
Im creating this model of a steel structure wich holds a circular gas pipe.
At first i created the circular shape having 4 points in common at the base of the pipe and it seems to work out good. however in the different upper lvls this gas pipe is uspposed to have a "guide ring" wich allows it to expand on its edge (Zdir).
I thought this could be done by using rigid links, or compatible nodes, however the meshing model of shell pipes creates only six edges, and it seems not working properly, moving the pipe by itself.
Hope u can solve this issue for me Thx.
