Revit to robot
Revit to robot
Revit to robot
Hi
When I export from revit to robot i receive an error message: Screenshot001.jpg
how fix it ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
If it is on W 10 then check:
http://forums.autodesk.com/t5/robot-structural-analysis/robot-2016-and-windows-10-compatibility-upda...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
I can't find a solution to my problem
Artur.Kosakowski
Autodesk Support
Autodesk Support
For W 10 you need to copy DRevit2Robot.dll from:
c:\Program Files\Common Files\Autodesk Shared\Extensions 2016\Modules\RSA\DRevit2Robot\
to:
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2016\System\Exe\
_____
This "action" is included in SP3 for Robot 2016.
Artur Kosakowski
thanks , it's worcking 🙂
Its working 🙂
