Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Revit and robot analytical model
2 REPLIES 2
303 Views, 2 Replies
hi Artur
Hi Artur  i need some advice how  link efficiently loose nodes between robot and revit.
  ASSUMING:ignoring analytical adjust in revit.
  once a structure is sent to robot like in my example can you:
  1)  link  NODE 4 to NODE 102(see below pictures) using Compatible nodes  tool or RIGID LINK TOOL?
if not  is it better to   use Analytical Adjust tool in Revit?.
personally  i like to adjust in Robot.Thank you
2 REPLIES 2
Rafal.Gaweda
1. look at bars 52 54 81to84 - distance between "two parallel" lines of bars is 1cm
2. I do not know what effect you want to get connecting these columns but maybe node 4 should be connected with node 115. If not - connect 4 and 102 by rigid link
Rafal Gaweda
in reply to: Rafal.Gaweda
thank you .
