retaining walls
retaining walls
Nairi85
retaining walls
Nairi85
Good afternoon!
Please tell me how to RSA, design a retaining wall?
Vote please, for the good and important idea 🙂
nairisargsyan.com
Nairi85
It became clear that the calculation of such structures in the program is not supported.
If I wish to add to the list, is there any chance that in the future this type of calculation to be realized?
nairisargsyan.com
Refaat
Hi
  1. I suggest you to (workaround) by using two panels (Vertical as wall and Horizontal as footing). But you have to do your own manually stabilities checks such as ( overturning , sliding … etc)
  1. You can download from French Forum (Expert tool 2012). Returning wall model is existing module and using French and polish codes only.
http://forums.autodesk.com/t5/robot-structural-analysis/article-installation-modifiee-des-outils-exp...
Hope this will help you
Refaat
Nairi85
Good afternoon! Thank you very much for the advice.
For the given task, I decided to take advantage of Monomakh-Sapr 2013.
nairisargsyan.com
