RETAINING WALL + FOUNDATION MODELLING - HELP
Javi1988
Javi1988
DIKE.pngHello,
I need to model the retaining wall shown in picture.
How would you model it? Please provide a couple of options.
I need to check stability against overturning and sliding plus
calculate the whole reinforced concrete cross-section.
Thanks in advance.
Javier.
Hi @Javi1988 ,
I've only designed a few retaining walls but from what I realized using two perpendicular panels is the most optimal way to model it. The other major issue is simply adding hydro-static and soil loads which are all available in the loads drop-down. As for your checks I would suggest looking over this topic;
https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/CloudHe...
For you specifically you should look into rotation and sliding but I found the topic very helpful during my analysis.
mathias_peron
Hi Javi,
I am not sure FE packages are the most effective way to design simple retaining walls. I have done it before and I find it extremely time consuming.
You can find simple softs that allow quick retaining wall design (TEKLA Tedds, etc...).
Have a good day!
