Results indicated graphically to table format
joseph.a.abouzeid
joseph.a.abouzeid
I am displaying the results using the "indicated graphically" option in Results/Maps as in the attachment.
I would like to display these same results on the indicated coordinates but in tabular format.
How is that possible?
Accepted solutions (3)
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @joseph.a.abouzeid
The results in the table can be shown either in nodes or centers of surface elements and you can filter the display to selected ones only.
Artur Kosakowski
joseph.a.abouzeid
Thank you Artur,
So I understand I will have to display the results on my custom coordinates graphically and copy the manually to an excel table.
Is there a way to suggest to Autodesk team to add this new feature where the user can add custom "non-node" coordinates to a result table?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Actually you can move nodes of the mesh to the points of interest (or create nodes there prior to running meshing) and access the values directly instead Smiley Wink
Artur Kosakowski
