Duplication of self weight in all load defined load cases - Cable structure
Message 1 of 9
Hi @Artur.Kosakowski
I have some questions regarding the following screenshots..
I have defined cable elements at the rear of the structure for lateral support however from a graphical display of the load cases I see that the self weight load case is duplicated in every other defined load case. Please explain why this is occurring?
Does this mean that the self weight is overestimated when I create combinations - I have checked the reactions for the dead load case and another vertical load case and I can confirm that the self weight is being duplicated?
Regards
Dane
Replies (8)
Message 2 of 9
mustafahesenow
Hi @Anonymous
Can you send us the model please?
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 3 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
This is as intended for these types of structures. In fact you first assemble it under self-weight and then you apply other loads. This is exactly what happens in Robot, the other loads are applied on an already deformed (under self-weight) model so the self-weight is applied only one time.
No, it isn't unless you define it again in any other than 1st (assembly) load case.
Artur Kosakowski
Message 4 of 9
Hi @mustafahesenow @Artur.Kosakowski
I have attached the model as reference.
Dane
Message 5 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Perhaps it would be enough if you use tension only bars instead of cables?
Artur Kosakowski
Message 6 of 9
Thank you for the assistance.
So my understanding is that the 1st load case is used to assemble the model and the state of the cable. How does this work within the load combinations where various load cases are defined?
I have been thinking of using tension only bars yes, I think I will change this.
In any case. has the definition of the cable model been done correctly regarding the load cases and combinations.
Regards
Dane
Message 7 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
1/ Assembling load case is always added to all consecutive simple load cases.
2/ Load combinations: assembling load case is added by default (even when it is not specified in the definition of combination) to the combination with the factor of 1. It is added only once rather than  from all simple load cases composing the combination (see point 1/).
If any factor different than 1 is specified for assembling load case in the definition of combination, this value overwrites the default value of 1.
Artur Kosakowski
Message 8 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to ask if i managed to explain the difference in handling the 1st (assembly) load case for cable models. Thank you.
Artur Kosakowski
Message 9 of 9
Apologies for the delay. I only got to your response this morning.
Yes, I believe I understand the approach taken now. Thank you for spot on explanation.
Appreciate the help Smiley Happy
Regards
Dane
