Result transform and plots
I completed one analysis where Local system for one of the panel was different than the adjacent panel. Hence when I plot the stress contour, I see discontinuity. Is there a way to tranform the results in given local system and make the contour plot consistent.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Geometry \ Properties \ Local Panel Direction
Rafal Gaweda
When I go and change the orientation I get following warning
I do not want to run the job once again. Whatever results I have, I want to transform that in my local coordinate system and want the controur plot also get updated. Because of minor problem where local axis of single panel is not correct, I do not want to run the job which takes more than 15 hours to complete.
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is for changing Z local axis direction.
After change you have to calculate model again.
Rafal Gaweda
