mesh problem
mesh problem
krabadavar
mesh problem
krabadavar
Hello everybody,
I'm having problem with a big project, I asked several times about in these forums.
Due to the imprecise geometry in the model, during the meshing lots of points and
edges divisions are added. If I take out a  single wall from the model, it has lots of
points and edge divisions, that I don't need(see attachment). Is it possible (for particular
panel and for the whole project) to remove these diisions and points and to re-mesh the
wall with normal mesh. Perhaps it's something very simple but I can't find how to manage
this.
http://www.filedropper.com/wallmesh
Milko
Rafal.Gaweda
Autodesk Support
Autodesk Support
There is nothing under the link you sent.
Rafal Gaweda
krabadavar
Wow - sorry lets try again with this:
http://www.filedropper.com/wallmesh_1
Rafal.Gaweda
Autodesk Support
Autodesk Support
1. File is corrupted - there is just only one wall in it but in inspector you see beams, columns and 159000 nodes
2. Open file in repair mode - wait ~45 minutes to finish operation
3. unmesh panel
4. delete all nodes from model
5. use this macro:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Addin-Weeding-remove-intermediate-points-for...
to remove division points from panel
Rafal Gaweda
