Restoring default materials
I have accidentally deleted all concrete materials predefined by program defaults.
Now I need to restore those materials.
I tried "restore initial program settings" in the job preference but it didn't work. I repaired my product using the installation wizard and that didn't help either.
Please let me know how to restore all materials that were defined by defaults.
Thank you
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @Anonymous
Please delete the following folder
C:\Users\%USERPROFILE%\AppData\Roaming\Autodesk\Structural\Common Data\xxxx
where xxxx Robot version (2019,2020 )
Krzysztof Wasik
Thank you! you have solved my problem.
