Resonance - foundation of wind turbine tower
Message 1 of 8
Hi everyone!
I would like to know if it's possible to analyse in Robot if the foundation of wind turbin tower won't avoid resonance with the wind turbine?
I was trying to do some simple tests (foundation plate) in modal analysis - but I'm not sure if it's good way? I have some results, but I don't know if the natural frequency of foundation plate on elastic springs  should change if I change Kz of soil? In my example there's no change in results.
Maybe it should be some dumper model for soil?
Thanks in advance.
Replies (7)
Message 2 of 8
t.sautierr
Post your file please.
Message 3 of 8
I have attached the file.
Regards
Message 4 of 8
Sorry for my English...
In first topic it should be "damper" not "dumper" 🙂
Message 5 of 8
t.sautierr
Your file contains only the plate.
If you want to analyse the resonance of the supporting structure of the turbine, you shall first analyse the supporting structure.
So :
Step one : put the supporting structure of your turbine (no need to add the slab)
Step 2 : make a modal analysis and look at the relevant modes
Step 3 : look at the frequency of the turbine and  look at the ratio F turbine / F structure -> come back to us.
About the foundation, I would be very surprised that you can have interaction between the turbine and a 2.5m raft ... : the frequency of your turbine will be high, and the one of the foundation will be governed by the soil -> much lower that a machine for most of the soils.
Message 6 of 8
Thank you for your reply.
It's not real project, I was just testing if it's possible to do it in Robot. I don't have any technical information about wind turbine that I can compare with.
Someone told me, that this kind of problem can happen in wind turbine support structure (checking also with foundation plate) and it's necessary to check it.
But you are right, this problem probably shouldn't exist in typical situations.
Message 7 of 8
t.sautierr
If you want to test then, you shall add spring support instead of elastic soil.
Ask R.Gaweda or P.Pulak from autodesk but I'm sure elastic soil can be taken into account in a modal analysis.
I you want to see the response thehn : Time History Analysis -> do it with fiwed support and then with sping support, you will see I you have got an amplification.
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, elastic soil or support definition can be used for modal analysis however you shouldn't define them with uplift.
Artur Kosakowski
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
