requist helping for design and anlysis column pocket foundation
srmdnadems
Message 1 of 17
srmdnadems
according to the image , I need your help for design and anlysis  column pocket foundation by using robot ? I want to do this by using finite elment with robot , please help me ?
Replies (16)
Message 2 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to use the RC Spread footing module of RSA
Artur Kosakowski
Message 3 of 17
srmdnadems
and how can difide it to finite element please ? it is very important for me , because i need to use robot instead of ansys 16.
Message 4 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Let me understand what you really need first. How would you design it in Ansys or by hand? What kind of results do you want to obtain?
Artur Kosakowski
Message 5 of 17
srmdnadems
I am very sorry for my late response ,
According for the image top, I need to use finite element as this method.
Message 6 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
In Robot you can also use (e.g. extruded) solids to model a column and a packet foundation however as contact elements are not available you would need to replace them with compression only bar elements.
Artur Kosakowski
Message 7 of 17
srmdnadems
do you mean I can not divide the column pocket to element as ansys ? whit is the alternative when someone using robot please ?
Message 8 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you mean generate mesh for solids then you can. See e.g.:
http://forums.autodesk.com/t5/robot-structural-analysis/extrude-solid-profile/m-p/5591372
Artur Kosakowski
Message 9 of 17
srmdnadems
yes my friend, you now exactly understand me, I need do that and give me ability to apply an axial load on a column with a particular load with eccentricity ?, and find the effect it on the column and the pocket, how can carry out that  with a clear video tutorial please ?
Message 10 of 17
srmdnadems
hi Mr. I am waiting you to response about my inqury, where can find a help information about your video above ? that what I need from you please.
Message 11 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you tell me what have you already defined based on the already provided information and where you get stacked please?
Artur Kosakowski
Message 12 of 17
srmdnadems
I have a column in pocket, I have one column which is immersed in a concrete pocket that will determine the dimension later , dimension of column will be 400 mm x 500 mm , then I will apply 300 kNm moment nd 100 kN vertical load on column .With is process, an eccentricity will be generated, I need to anlyse this system by using finite elemint like first below vedio :
https://knowledge.autodesk.com/community/screencast/2ad6fbed-cdd4-4362-82ee-db058f88b29c
Message 13 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
So you know how to extrude a column and you should also know how in a similar way create a foundation Smiley Wink
I'm attching a sample model that you may use as a reference.
Artur Kosakowski
Message 14 of 17
srmdnadems
I have seen your file about pocket foundation , you are impressive me completely , how did you do that please ? your file is what I need , but may I want to change some detail about the dimention, thank you very much, and I need how to do that Mr. Kosakowski ? because the supervisor and the experts may ask me about how to do the , so I need the details please.
Message 15 of 17
srmdnadems
thank you Mr.Kosakowski from my heart , and I need please to know how can you achevie the atached file ? I am waiting and thank you again for the file , you are a great man indeed.
Message 16 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 17 of 17
srmdnadems
thank you very muck from my heart Mr.Kosakowski , you are a great man , ten stars for you.
