Reinforcement problem
Hello Guys,
What does it mean, when it say:" Zones do not cover all the regions where reinforcements is required"?
What should i do?
Thanks in advance
Artur.Kosakowski
Autodesk Support
Autodesk Support
Such situation was described in the 5th Robot webinar which recordings I strongly encourage you to watch from:
http://forums.autodesk.com/t5/robot-structural-analysis/robot-structural-analysis-webinars/td-p/5523...
The suggestion for such situation was:
"Make sure you define reinforcement zones in such a way they cover whole slab for each reinforcement type. In case you see this situation for automatically generated ones try to switch to the regular grid type and run reinforcement generation again"
or use the suggestion from post 23 from: http://forums.autodesk.com/t5/robot-structural-analysis/model-warnings/td-p/5169033
The other situation has been described in:
post 3 from http://forums.autodesk.com/t5/robot-structural-analysis/slab-reinforcement-problem/m-p/3924851
Artur Kosakowski
I did that with the mesh, and when I try to calculate it just frez. Nothing is wrong with my computer. I use robot on a gaming computer and have calculated before in robot with this computer.
I hope someone will help, me.
I am very pressed right now.
Please guys.
Thanks in advance.
It was my computer. I installed Robot 2014, and it went well 🙂
