Model warnings
Model warnings
Message 1 of 42
Model warnings
I have 3 warning after calculated a 3 storey RC frame:
-incoherent mesh on edges
-cohesion of the calculation model has been provided by definition of kinematic constraints in incoherent points of finite element mesh
-linear load as not been applied to a pannel
I have tryed to follow other post and change the mesh settings but it is even worse.
I have attached the model file:
http://www.filemail.com/t/36154234cbb54dc9834ae45ca2b1d2d6
thank you
Replies (41)
Message 2 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Structure-verification/m-p/3334787#M2792
Check coordianates of your lines create for loads application or apply loads this way:
Rafal Gaweda
Message 3 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
Model is inaccurate
See video how to correct mesh and geometry:
Meshed model attached
Rafal Gaweda
Message 4 of 42
Thank you.
I don't understand what you have done with the walls using the spreadsheet. Is it something I will need in future for other models to avoid errors?
Message 5 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
I have corrected coordinates. Wall were not made in one plane
Rafal Gaweda
Message 6 of 42
Thanks again.
I have removed few columns and run the calculation without re-mesh the slab. The max moment is 75.
Then I have meshed the slab following your instruction. The moment is decreased at 60 and I don't understand why. (the columns removed are at the opposite of the building, far from the max moment point).
Shall I trust in the new mesh with the lower value?
thank you
Message 7 of 42
t.sautierr
have you same density of mesh?
is coarse, maybe the new one misses the peak ...
Message 8 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
FEM results strongly depend on meshing
Rafal Gaweda
Message 9 of 42
Yes the mesh size is the same... 1 m
Message 10 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not understand. File please.
Rafal Gaweda
Message 11 of 42
http://www.filemail.com/d/lmrjcywrzmtyycu
I have attached both model. P3 is meshed by you.
Thank you
Message 12 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is what I see :
Rafal Gaweda
Message 13 of 42
This is the map for Y moment at 1st floor.
Message 14 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
I wrote before: "FEM results strongly depend on meshing"
Rafal Gaweda
Message 15 of 42
Thank you Rafal.
How can I connect a steel frame on top of the concrete slab?
Message 16 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 17 of 42
Hi Rafal,
Thanks for your advise so far. This building is proposed as a 3-storey RC, (+0m to +9m), with a 2-storey steel frame on top (+9m - +15.25m).
Looking at level 9.0, the steel frame columns over do not line up with the RC columns below. Therefore , my question is, is it possible to define pinned supports to the steel columns, on the RC floor at level +9.0m? Other posts suggest the use of rigid links, but I cannot understand this.
The other option is to create a separate steel model, and apply the reaction forces to RC model, but i would prefer just to have one model if this is feasible.
Many thanks, Franco
Message 18 of 42
Rafacascudo
Use "rigid links" to link the concrete columm top node to the steel columm botton node. Then just use "bar releases" to pin the botton part of your steel columm
Rafael Medeiros
Message 19 of 42
Rafal.Gaweda
Autodesk Support
Autodesk Support
Possible solutions:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Only-reaction-for-new-model-API/m-p/3659280#...
Rafal Gaweda
Message 20 of 42
Rafal,
Thanks for your reply. However, the steel columns do not line up with the concrete columns below. The slab at +9.0 is required to transfer the loads.
Can rigid links be applied to the actual floor slab?
