I have a general question relating to designing reinforcement for walls.
I have assigned the walls of my structure as “structural object = panel” and I am then designing the same way as slab panels,
with the exception that I am using the Analytical Approach for designing the required reinforcement (I use Equivalent W&A Moments for Slabs) as the axial load is high in the walls.
My query is, which forces should I be using to verify the proposed reinforcement sizes generated in Robot when using the analytical method?
I am getting some high required rebar sizes yet when examining the detailed moments and axial forces in the wall they all seem quite small?
When designing the slabs previously I have been able to check the Equivalent moments using the Complex Tab in the Map Results and do some hand calculations to verify Robot proposed sizes and this worked quite nicely
