problem with the integration between Robot and Revit
Hello.
I published this post but no one answered me . Can you please help me?
I have a model in Revit consisting of walls, foundations slab, slab and column
I integrated this model to Robot and calculated the reinforcement of all elements except the wall because I'm using the European Standard.
After the calculation , I update the model from Robot to Revit but really only reinforcements of column is updated in Revit.
How can I pass the rest of reinforcements from other elements?
I have attached the Robot model if necessary
        http://www.4shared.com/file/FIcxmdlGba/modelo_punzonamiento_2.html
Thanks!!!!
Hello
Thanks!!!!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Really, That link doesn't help me because in my case, The reinforcements in beams and columns works well.
My problen is about structural wall, slabs and foundation slabs. Why Revit doesn't update the reinforcement of this elements?
In conclusion, the reinforcements of walls and slabs can not be updated from Robot to Revit. That is what the link says.
However, these links are a few years ago. In versions 2015 or 2016 this problem has not been solved?
If the problem persists, It is very difficult to work in BIM with this software.
Rafal.Gaweda
Autodesk Support
Autodesk Support
It is not problem. It is a limitation.
Transfer of slabs and walls reinforcement is not implemented yet.
Rafal Gaweda
