Reinforcement drawings for foundation beams
andrea_pontiggia
andrea_pontiggia
I can not transfer a foundation beam in Autocad Detailing, and I can not even export your drawings armor in robot directly.
Why is that?
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Generate drawing(s) in Robot
2. Save rtd file
3. Close Robot
4. Start ASD Reinforcement
5. Import drawing(s) in the way shown on the attached picture
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Rafal.Gaweda
Autodesk Support
Autodesk Support
andrea_pontiggia
Trying the first solution this message appears.
I've tried using other methods but I can not. What can I do? Why Robot with these elements all these problems?
Also do to create the drawing in Robot, how can I create a unique drawing with all segments of the foundations?
Robot divided into a number of boards equals the number of segments.
thanks
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
Make a movie that illustrate your actions or create step by step description with screen captures) and attach the rtd file with the drawings you want to open.
You need to select the right template (see the attached picture).
Artur Kosakowski
