Reduced Results for Panels
Message 1 of 13
I was trying to get the reduced results for various panels and combinatios and I noticed that the cuts available are defined as horizontal and vertical.
When evaluating an vertical panel, I can understand in which direction the cut will be made, but what about an horizontal panel? What does RSA assume to be the vertical and horizontal direction of the cuts?
Thanks in advance
Replies (12)
Message 2 of 13
Refaat
 Hi
I hope you will find the answer of your question in this capture and the link of AKN.
Refaat
https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/CloudHe...
Message 3 of 13
I'm sorry, but I still can't get the reason to define a vertical and a horizontal cut in an horizontal panel.
Your link is indeed explainig about the definition of the cuts, but does not explain what is done when the panel is not vertical. Is the vertical cut in the XZ plane and the horizontal cut in the YZ plane or vice-versa? And are they defined in relation to the local or global axis?
Message 4 of 13
Refaat
Hi
Please, try to take a look to the following link which explains how does RSA calculate the reduced forces for cuts.
http://help.autodesk.com/view/RSAPRO/2017/ENU/?guid=GUID-3936FDA3-5DFD-4F31-B16A-F0208A451282
I hope this will helps
Refaat
Message 5 of 13
I'm sorry, but my problem is not with the calculation of the reduced forces. I just can't understand how the program defines the horizontal or vertical concept in an horizontal panel (this is important when analysing various panels through the information given in the tabel "reduced results").
For example,in the image below, why is A1 an vertical cut and A2 an horizontal cut and not the other way around?
Thanks in advance
Message 6 of 13
Refaat
Hi
As far as I understand you. The first defined cut should be (A1) whether parallel to (Global - X or Y) or even parallel to any vector. And you can read them simply as I referred in the capture.
Refaat
Message 7 of 13
I'm sorry but it doesn't.
The problem is not about the cut itself, it's about the definition in the table of results.
If I wanted that cut to be displayed, which cut should I choose? The vertical or the horizontal? This is easily understood if we are leading with a vertical plane, but not clear when the panel is horizontal.
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
In your case both middle (vertical and horizontal). You can identify them by their node numbers:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 9 of 13
Refaat
Message 10 of 13
I see.
But is there anyway I can determine it wihtout checking for each panel? Any convention to its definition? Or do I have to go one by one and deterime which cut I want?
Thank you both
Message 11 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 12 of 13
I'm working with reduced results for panels, and I've read your post on explaining the directions for the cuts.
Please see the pictures attached. The locations for the cuts is constant, but the results aren't. I've tried to analyze with both Coons Meshing and Delauney, and the pictures attached are with delauney. With Coons I get constant result. Could you please make an effort of explaining me why? Is coons the suggested meshing method for walls and reduced results for panels?
Any rules of thumb for link between local panel direction and meshing method for this matter?
Message 13 of 13
I tried to replicate your case but i couldn't produce the same issue. Can you please attach the file?
