Hi Team,
would any one be able to advise why there is zero to all stress and forces result in the truss?
Regards
Eric Wu
Solved by Artur.Kosakowski. Go to Solution.
Hi @ewu168
The deformation under self weight is small so you need to adjust the display units and precision.
I have also corrected the excessive definition of releases so that there is no instability warnings.
