RE: Panel Openings
RE: Panel Openings
RE: Panel Openings
I am experiencing problems with the creation of panel openings. Robot is not recognizing the definition of it. I ran the Calculation Component Registration and that did not assist.
Any suggestions as to how to solve this modelling issue?
Sameer Ramgoolam
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
I will like the 3.2m x 2.045m contour on the top right to be an opening. I tried all methods of meodelling and non is working. The main panel (Panel 9) will be the 250mm thk raft.
Sameer
Rafal.Gaweda
Autodesk Support
Autodesk Support
Deactivate ACIS and redraw panel:
or you can make opening in standard panel this way:
Rafal Gaweda
Thanks you. I have'd the same issue.
