RCBeam Foundation would not create Drawings.
Can someone look into this? I'm not sure if it is a bug or not, but this RC beam Foundation would not let me create a drawing.
See file attached.
Greg
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You have the drawing template not selected:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Arthur, it creates the template, but then switches immediately to the foundation view. Could you attach the file with your settings so I can try out something?
Also has there been a new update?
Greg
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
At this point try to use: Tools > Customize > Open layouts from template
Try to rename your CfgUsr folder and start a new project to see if this helps.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Hi Arthur,
I downloaded the updates and restarted the workstation and it worked fine. thanks for the help.
Greg
