RC Wall Design
RC Wall Design
Message 1 of 11
RC Wall Design
please somebody should help me find solution to this problem
Accepted solutions (4)
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
For BS 8110 you need to design this wall in the RC Slab Reinforcement module instead. You will find the information how to decide which Robot module to send the panel to in the recording of the 5th Robot webinar available from:
http://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td-...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 11
thank you Artur. I think I understood your webinar in that regard. but it still did not work for me. let me explain what I did; since you said no need to calculate required reinforcement for the wall, thus, from the geometry I selected the wall and I click on the PROVIDE REINFORCEMENT OF RC ELEMENT to calculate the needed reinforcement. but the same message keep coming.
could you please help me with steps to be take to move on with my design
thanks for your anticipated support.
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file with this wall please?
Artur Kosakowski
Message 5 of 11
thanks for your support.
please see link below.
https://we.tl/IEdpUVOSGU
Chris.
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 7 of 11
thank you so much. please let me ask a question; WHY DID YOU CHENGE THE WALL TO PANEL?
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Have you watched the recording of the webinar? Smiley Wink
This sets the design module to use for reinforcement calculations. As the RC Walls one doesn't support BS or BS EN code you need to use the RC Slab Reinforcement instead.
Artur Kosakowski
Message 9 of 11
ok. please which of the code support it to be design as RC WALL
Message 10 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
NF EN (French NAD for EC3) and ACI.
Artur Kosakowski
Message 11 of 11
Thank you so much Artur. you been so wonderful, I appreciate.
