03:40 AM
Hi there,
I am trying to design two-way spanning concrete panels in Robot which will make up the design for a spiral shaped car park ramp. The ramp spirals around a cylindrical core/shear wall with beams spanning out from the shear wall to outer perimeter columns to help support the width of the ramp. The length of the ramp is supported via edge beams which are intended to be upstands.
- The edge beams are curved on plan and in elevation and have been modelled as short bar elements. Is it possible to create a "super bar" from the small bar elements in the concrete design options. I know this is possible in the steel design options but I can't find this in the concrete design facilities.
- If I attempt to import a group of elements representing the edge beams between two adjacent columns into the provided reinforcement module, Robot crashes every time. What is the cause of this?
- What is the recommended way to tell Robot that the beams are upstands at the edge of the ramp panels and that the beams span onto the columns?
