RC Slab - Provided Reinforcement
ashley_calleja
Message 1 of 8
ashley_calleja
Hi all, I am designing the reinforcement of a concrete two way slab, and when clicking on provided reinforcements tab, I am getting the same required reinforcement ,At, for both X and Y direction as seen in the attached photos. Also the top arrow is remaining in the same direction. Is there any way I can fix this please?
Replies (7)
Message 2 of 8
Simau
@ashley_calleja
Could you zip and share your model
M. Agayr
Message 3 of 8
ashley_calleja
Model attached. Thank you
Message 4 of 8
Simau
Hi @ashley_calleja
This option must be used for your structure
I made some modifications to your model:
- Slab remeshed
- Selfweight added and some combinations created
- Required reinforcement calculated before provided reinforcement
- Look at reiforcement type parameters i used here
Results
M. Agayr
Message 5 of 8
ashley_calleja
And what if I want to change the thickness of concrete to 300mm? Do I need to make any additional adjustments?
Message 6 of 8
Simau
No,
Change thickness and run the model again
M. Agayr
Message 7 of 8
ashley_calleja
Thank you. I noticed that with the model the moments in the beam reduced significantly from what I had. Is there any reason why this changed? Thank you for your responses I am still new at using Robot.
Message 8 of 8
Simau
@ashley_calleja
I didn't change anything in your model except a tighter meshing.
M. Agayr
