RC Slab Provide Reinforcement - Ar/At = 0 error
@Anonymous Artur Kosakowski edited the topic for better findability
mustafahesenow
Hi @Anonymous
Send us the model please
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
help
mustafahesenow
Hi @Anonymous
The attached model is not the same shown in the picture (there is no combinations and no calculated slab )
In order to check your problem please send us the model updated and the slab the one has problem opened in provided reinforcement to help you quickly)
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Most likely the generated reinforcement zone is slightly smaller than the slab itself. Try to switch to the regular grid and generate reinforcement again.
Artur Kosakowski
tank you artur  you are a professional:)))
