RC slab design
RC slab design
romanAV48J
Message 1 of 8
RC slab design
romanAV48J
I am designing a relatively simple thick RC slab.
The analysis indicate defections equal to 18mm. The bending results are as expected.
In the reinforcement design the deflection's are shown as 101mm and the rebar required way above the expected.
Why is there such a great difference between the deflections in the analysis and the reinforcement design module.
Replies (7)
Message 2 of 8
Simau
Hi @romanAV48J
Could you zip and atach your model
M. Agayr
Message 3 of 8
romanAV48J
The zip file is attached. Many thanks.
Message 4 of 8
romanAV48J
Hi Simau,
The model is attached. Hope that you will get it.
Many thanks,
Roman
Message 5 of 8
Simau
Hi @romanAV48J
First are you sure about the direction of the LL1 load case.
You can't compare the deformations from Maps and those calculated in required reinforcements which depend on the parameters in "reinforcement type"
I created new ULS and SLS combinations according to the BS code to design the slab:
Model attached
M. Agayr
Message 6 of 8
romanAV48J
Thank you for this Simau.
The model is of an  shaft base. The LL is due to water pressure/heave this is why it is pointing up. The FOS are also slightly different from the FOS in the codes.
I an relatively new to Robot and still getting grips of how it works. In the slab model V1 there 2 different displacements indicated. One 8mm the other 20mm.  What loading condition do the 8mm and 20mm represent? Does the reinforcement area (required/provided) affect the deflections output? Can the crack width limit be changed in "reinforcement parameters". I have tried to change the crack width limits as an experiment but it did not affect the results.
All the best
Roman
Message 7 of 8
Simau
Hi @romanAV48J
I recommend you to watch this webinar (starting at 19:25)
https://www.youtube.com/watch?v=YvVRNFH8_cc&list=PLY-ggSrSwbZqow_60fiqJwS69mg1nQMzk&index=5&ab_chann...
M. Agayr
Message 8 of 8
romanAV48J
Much appreciated. Thank you for your time and help.
