RC Reinforcing and Isolated Nodes
conor_coburn
conor_coburn
1) I have a number of Isolated notes that wont go away, and if I try and selcet them and filter to just show teh selction they dont show up.
2) I have deleted the Automatically generated RC in the RC SLab reinforcing Module and manually added, I am getting a number of errors that I need help with as all the manual reinfocing I added appaers to meet requirement.
3) The model and some screen shots are attached.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @conor_coburn
I re-meshed the model switching off the user of the kinematic constrains and regular meshes and deleted the isolated nodes from the Nodes table
The reinforcement zones you defined don't cover the whole slab:reinforcement zones1.JPG
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
You may want to use the attached model for the slab reinforcement calculations.
Artur Kosakowski
conor_coburn
In relation to the reinf. I have done it over and over a couple of times and had the whole roof covered including the part at the corner. If you take the model you sent back to me and put in the reinforcing manually in the -x direction. 3 zones H12@150 , 2 big and the small one in the middle left corner. I end up with error from this exercise. See attached.
Can you let me know if I can ignore these errors or direct me on how to avoid them. Thanks.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @conor_coburn
For the X- yiu have 3 zones with the same reinforcement distribution so you can easily replace it with one. For the others see the attached model.
Artur Kosakowski
