Error display beams
Error display beams
ledinhchinh0409
Error display beams
ledinhchinh0409
Hi everybody!
I have a model
The beams do not show, when choosing "stories -legend ..."
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
Try to use:
Geometry > Stories > Assign Manually > Select these beams and assign them to the right story.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
ledinhchinh0409
Hi. @Artur.Kosakowski
Thanks for the reply. I used your way. But not successful. This is very strange, I attach the model, wish you help me. Thank you!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
You need to run model generation.
Artur Kosakowski
ledinhchinh0409
hi. @Artur.Kosakowski
This is a  mystery
