RC column design report
Hello!
I am trying design RC columns with Robot 2015. I have some problems with reports and column drawings. First, is it posible to get in column calculation report NM diagram? (See col_res_diagram)? Second, in column drawing I can not get column rebar diameters. Why, because there is cheked to show that information in Drawing Parameters > Reinforcement Description? (See  col_drawing; column_drawind_d)
Thanks!
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, it is not the part of the note but you may copy and paste it to the rtf using e.g. Windows Snipping Tool.
Do you use a standard reinforcement bar database or you created (or edited the existing) your own one?
Artur Kosakowski
