RC Column design - manual combinations
MUHANNAD.ABU_ABDO
Message 1 of 8
MUHANNAD.ABU_ABDO
why is manual combinations off when i select column to design .. how i generate it ?5346.jpg
Muhannad M.Abu Abdo
Structural Design Engineer
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
You need to define manual combinations in the model first (Loads > manual combinations). Otherwise combinations are generated automatically by the RC Design module based on the simple cases (this is as far as I  can see your case).
Artur Kosakowski
Message 3 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
example movie: http://screencast.com/t/iwxoIyqYnUU
Rafal Gaweda
Message 4 of 8
MUHANNAD.ABU_ABDO
I made the combinations .. when i select beam the manual combinations appear .. but when i do it with column it's not work
Muhannad M.Abu Abdo
Message 5 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Attach the model please.
Artur Kosakowski
Message 6 of 8
MUHANNAD.ABU_ABDO
file is here
http://www.filemail.com/d/bnmnclhvzanditk
B.R
Muhannad M.Abu Abdo
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I don't have any issue with using the manual combinations fro RC Column design in your file.
Try to install Robot 2014 SP3 (replaced by) SP5.
Artur Kosakowski
Message 8 of 8
MUHANNAD.ABU_ABDO
Thanks very much .. it's work with RSA 2014 SP3
Muhannad M.Abu Abdo
