I would like to ask how to correctly define the parameters of the beam carrying the load from upper column ?
Reading a similar post, I noticed that all supporting elements can be selected and approved in the first step when the load combination window appears.
Can this window be displayed again (in any time of design) to redefine the supports or can it be done only once at the beginning ?
A columnn transmitting the load from above is seen as a supported beam - both in the geometry window and in the drawings.
Can it be turned into a "physical" column or is it impossible ?
