RC beam design
RC beam design
Message 1 of 8
RC beam design
Hi all,
Can someone help me out with RC beam design modules. Very new to this but hoping to master as some point as my intention is to use robot only for the whole analysis and design without requiring another software package. See attached errors i get when analysing.
thanks
Kyp
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
See the slide from the 4th Robot webinar:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 8
it says calculations not performed. What have i missed here?
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Enter numbers of combinations in the Calculations dialog as the load selection fields are empty.
Artur Kosakowski
Message 5 of 8
is there a guide for the design of RC members? the module is not very user friendly.
Message 6 of 8
How does one fix this error ? see attached
Message 7 of 8
Rafacascudo
Check the available webinars
Build your Robot Structural Analysis IQ - YouTube
Rafael Medeiros
Message 8 of 8
khimpitou
set you column dimension
