RC beam connection with column
Message 1 of 17
I face a problem regarding the connection of a beam to column but not in the center of gravity of the column. What i have to do? And something else, if i have a slab foundation with beams what have to be the supports of each columns?
Thank you.
Replies (16)
Message 2 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure what kind of effects you want to include in your design. Could you give us more detailed description of your objectives?
Artur Kosakowski
Message 3 of 17
teixeiranh
Or at least some more geometrical information on that problem.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Message 4 of 17
Please check the attachment file.... Also, have a look on foundation elastic ground...
Message 5 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
For your original question (http://forums.autodesk.com/t5/robot-structural-analysis/wrong-concomitants-in-table/td-p/5772528) you may use UX offsets (shortening) for beams however the question is if you actually should model your columns as bar elements or as vertical panels instead.
For the foundation - I think that you may consider removing fixed vertical supports under columns as you already provided vertical restrain in the definition of the raft foundation thickness.
Artur Kosakowski
Message 6 of 17
What do you mean as bars elements or vertical panels? Could you please make a change to the file that i uploaded in order to understand what do you exactly mean?
Message 7 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 8 of 17
Lets say that i will put it as a bar. Its impossible again to drag a beam from the side of the column.
Message 9 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
A bar element has got no real size (cross section is only its attribute) so a side of a column is sort of "virtual" . What is the effect you want to achieve?
Artur Kosakowski
Message 10 of 17
As you can see in the pictures the 20x50cm beam is not connected to the 80x20cm column. How can i make the connection?
Message 11 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may consider using "horizontal" rigid link as discussed in:
http://forums.autodesk.com/t5/robot-structural-analysis/beam-lateral-offset/m-p/5463882
Artur Kosakowski
Message 12 of 17
Thank you for your answer. Another one problem I face is that when I try to solve an RC slab, I dont take the expected results regarding the top required reinforcement. The center of the RC slab should't be without reinforcement? Please see the attachment.
Message 13 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Unless they are cantilevers Smiley Happy
Artur Kosakowski
Message 14 of 17
Yes sure. I know the basics. 🙂 I am talking for the rest of the slabs which are not cantilevers. Solve one in order to see. Unless they are not connected with the right way.
Message 15 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 16 of 17
So, you think I dont have problem with my model, regarding the offset between beams and slabs or anything else...
Message 17 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
I haven't thoroughly checked your model which is going to be your responsibly based on your knowledge of the intended behavior of the structure. I only checked if the upper reinforcement distribution in slabs is as generally expected and IMHO it is as expected.
Artur Kosakowski
