QPR SLS Cracking Results
luismrf
luismrf
i´m desingning a pool, i did something wrong because in the result for QPR SLS the results are too wide for cracking, i did something wrong but i don´t know what, i need someones help please.
regards,
Luis
Simau
@luismrf
Your panels parameters are not good as there is uplift to be taken into acount.
You have also to remove planar support from the slabs.
Set slab as maciça 20 UZ+ and vertical walls  as maciça 20 UZ-
Model attached
M. Agayr
Simau
There is no available X+ cracking results for the applied loads (too weak). If you increase loads ( for example water at 3000 kg/m3 and DL with 30 kpa applied to the raft) you'll get some X+ cracking results.
You may also decrease slabs and raft thickness
M. Agayr
luismrf
Thank you @Simau,
-removing the planar support from the slab make an error appear while calculating, but it´s not critical because RSA calculates, is there any way to remove this warning\error?
- Is it possible to see the changes you made in the Maciça UZ+, and Maciça UZ -? i can edit them  but how can i see the parameters?
- I want to check the steel reinforcement for the sheer in the walls, how is the best way to check it? Does the RSA provide it?
thank you
Simau
@luismrf
1- Type 3 instability is not critical as long as displacements are not inconsistent
2- Look at screenshot below
2- I am not sur i understand your concern. Could you tell us the code to apply to this verification
M. Agayr
