Python Api
Python Api
cool.stuff
Message 1 of 21
Python Api
cool.stuff
Good morning!!!
When I try to define a support in Python with the follwoing code,
sup = labels.Create(rp.IRobotLabelType.I_LT_SUPPORT, 'sup')
sup_dt=rp.IRobotNodeSupportData
sup_dt = sup.Data
sup_dt.UX = 1
sup_dt.UY = 1
sup_dt.UZ = 1
sup_dt.RX = 1
sup_dt.RY = 1
sup_dt.RZ = 1
labels.Store(sup)
I got the error:
File "<ipython-input-56-8cf91e21e0e8>", line 1, in <module>
sup_dt = sup.Data
AttributeError: '__ComObject' object has no attribute 'Data'
Can someone help me?
Replies (20)
Message 2 of 21
JacquesGaudin
You can try casting the object returned by ``labels.Create`` to ``IRobotLabel`` to make sure it implements the Label interface. I do that often since I am running the code on CPython through PythonNet.
sup = IRobotLabel(labels.Create(rp.IRobotLabelType.I_LT_SUPPORT, 'sup')
sup_dt = IRobotNodeSupportData(sup.Data)
That should solve the issue. 🤞
Message 3 of 21
cool.stuff
Many thanks for your answer and sorry for my late one!!!!
I tried what you said but stil get an syntax error:
import clr
import math
import sys
import csv
clr.AddReference('C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2019\System\Exe\Interop.RobotOM.dll')
import RobotOM as rbt
from System import Environment
from RobotOM import *
from System import Object
robapp=rbt.RobotApplicationClass()
struc=robapp.Project.Structure
node=struc.Nodes
bar=struc.Bars
labels=struc.Labels
stress=struc.Results.Bars.Stresses
force=struc.Results.Bars.Forces
sup = IRobotLabel(labels.Create(robapp.IRobotLabelType.I_LT_SUPPORT, 'createdSupport')
supData = IRobotNodeSupportData(sup.Data)
supData.UX = 1
supData.UY = 1
supData.UZ = 1
supData.RX = 1
supData.RY = 1
supData.RZ = 1
labels.Store(sup)
Any aideas why?
Message 4 of 21
JacquesGaudin
Please include the full error message including line number. It makes it much easier to spot the mistake. It may just be a typo so please copy exactly the code you are trying to run.
Message 5 of 21
cool.stuff
Many thanks for your answer!!
My full code (the is like this one):
import clr
import math
import sys
import csv
node=struc.Nodes
bar=struc.Bars
labels=struc.Labels
supData.UX = 1
supData.UY = 1
supData.UZ = 1
supData.RX = 1
supData.RY = 1
supData.RZ = 1
labels.Store(sup)
The error:
runfile('G:/WIP/RSAP Python/RSAP_Test.py', wdir='G:/WIP/RSAP Python')
Traceback (most recent call last):
File "C:\Program Files (x86)\Microsoft Visual Studio\Shared\Anaconda3_64\lib\site-packages\IPython\core\interactiveshell.py", line 2963, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File "<ipython-input-2-727407a95006>", line 1, in <module>
File "C:\Program Files (x86)\Microsoft Visual Studio\Shared\Anaconda3_64\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 827, in runfile
execfile(filename, namespace)
File "C:\Program Files (x86)\Microsoft Visual Studio\Shared\Anaconda3_64\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 110, in execfile
exec(compile(f.read(), filename, 'exec'), namespace)
File "G:/WIP/RSAP Python/RSAP_Test.py", line 45
SyntaxError: invalid syntax
This is what I get..
Thanks! 🙂
Message 6 of 21
JacquesGaudin
There is a bracket missing at the end of
Message 7 of 21
JacquesGaudin
There is a closing bracket missing at the end of:
Message 8 of 21
cool.stuff
Many thanks!!! 🙂
What a silly mistake -.-
But now I get the following error:
sup = IRobotLabel(labels.Create(robapp.IRobotLabelType.I_LT_SUPPORT, 'createdSupport'))
AttributeError: 'RobotApplicationClass' object has no attribute 'IRobotLabelType'
I've changed to sup = IRobotLabel(labels.Create(robapp.IRobotLabel.I_LT_SUPPORT, 'createdSupport')) but stil get the same..
Message 9 of 21
JacquesGaudin
In fairness, the error was mine in the original answer 😉
IRobotLabelType is in the RobotOM module so it should be:
sup = IRobotLabel(labels.Create(RobotOM.IRobotLabelType.I_LT_SUPPORT, 'createdSupport'))
or since you import * from RobotOM:
sup = IRobotLabel(labels.Create(IRobotLabelType.I_LT_SUPPORT, 'createdSupport'))
Note if you want to look at the list of names defined in an object or module, you can use:
dir(myObject)
dir(myModule)
It helps locating things as the API documentation is sometimes incomplete.
Message 10 of 21
cool.stuff
Works like a charm!!! :))
Many thanks for solving and for teaching a few useful tricks 🙂
You're the man!!! 🙂
Message 11 of 21
ArunNDinesh
@cool.stuff Can you please share the final code which is working? I just budding some python integration with RSA. The code in the thread is not working for me.
import clr
import math
import sys
import csv
clr.AddReference('C:\Program Files\Autodesk\Robot Structural Analysis Professional 2023\Exe\Interop.RobotOM.dll')
RobApp  = RobotApplicationClass() # Connect to  Robot Structural Analysis
RobProj = RobApp.Project # To Get current project
RobStruc = RobProj.Structure # To Get current model
node=RobStruc.Nodes
bar=RobStruc.Bars
labels=RobStruc.Labels
stress=RobStruc.Results.Bars.Stresses
force=RobStruc.Results.Bars.Forces
sup = IRobotLabel(labels.Create(RobotOM.IRobotLabelType.I_LT_SUPPORT, 'Sup'))
supData.UX = 1
supData.UY = 1
supData.UZ = 1
supData.RX = 1
supData.RY = 1
supData.RZ = 1
labels.Store(sup)
Message 12 of 21
JacquesGaudin
@ArunNDinesh
Please post the error message, we need to know how it's not working to help you.
Message 13 of 21
ArunNDinesh
Unhandled Exception: System.NotSupportedException: Cannot create uninitialized instances of types requiring managed activation.
   at System.Runtime.Serialization.FormatterServices.nativeGetUninitializedObject(RuntimeType type)
   at Python.Runtime.ClassObject.tp_new_impl(BorrowedReference tp, BorrowedReference args, BorrowedReference kw)
   at Python.Runtime.NativeCall.Call_3(IntPtr fp, BorrowedReference a1, BorrowedReference a2, BorrowedReference a3)
   at Python.Runtime.MetaType.tp_call(BorrowedReference tp, BorrowedReference args, BorrowedReference kw)
@JacquesGaudinThank you for the response. I'm just learning the python integration with RSA, So I'm just using the limited threads and curious to see how python is calling the objects in RSA. Thanks for your time in advance 🙂
Message 14 of 21
JacquesGaudin
@ArunNDinesh
This is rather unusual! Do you know which line triggers the error?
Message 15 of 21
ArunNDinesh
I do have issues in these many lines. I don't know what is the reason and got stuck!!
@JacquesGaudin Please help if you know . . .
Message 16 of 21
JacquesGaudin
@ArunNDinesh
I need to understand which line causes the error. Could you add some print statements in your code to establish where it stops?
The messages saying the import cannot be resolved look like warnings emitted by your IDE, I wouldn't worry to much about them for now.
Message 17 of 21
ArunNDinesh
@JacquesGaudin I already copied the print statements. It seems the issue starts from Line 6. Is this working for you?😕
I am able to open ROBOT application using
import subprocess
file=subprocess.Popen('C:\\Program Files\\Autodesk\\Robot Structural Analysis Professional 2023\\Exe\\robot.exe') and there is no issue. But unable to integrate other functions with ROBOT
Message 18 of 21
JacquesGaudin
What I mean by print statements in the code is to add some lines in the like of ```print('Robot import successful')``` after each line of your script.
For example:
import clr
print('clr imported')
clr.Addreference(<your path>)
print('Reference to Robot added')
import RobotOM
print('Robot imported')
This will tell you on which line the program stops.
Message 19 of 21
ArunNDinesh
Hi @JacquesGaudin Thank you for the clarification. Added the print statement and it seems like line 19 is having the issue.
import clr
import math
print('math imported')
import sys
print('sys imported')
import csv
print('csv imported')
print('Robot imported 1')
print('imported 2')
print('imported 3')
print('imported 4')
print('imported 5')
print('imported 6')
print('imported 7')
print('imported 8')
print('imported 9')
node=RobStruc.Nodes
bar=RobStruc.Bars
supData.UX = 1
supData.UY = 1
supData.UZ = 1
supData.RX = 1
supData.RY = 1
supData.RZ = 1
labels.Store(sup)
Message 20 of 21
JacquesGaudin
Interesting! I usually get the RobotApplication from:
RobApp  = RobotApplication()
rather than RobotApplicationClass(). Does that solve the issue?
