Problems with nodes with import files of Revit Structure .
10:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hello evrybody,
my name is samuel and i have a quetion for all of you.
when i have a file of Revit, esample a structure and import the file in Robot Analysis , is possible that the file don t is compatible near the nodes.
At the bottom of The axis of the beam there is node, if the nodes don t is joint with other beams the software produce an error.
This problem don t allow of analysis of structure.
How i can correct this problem , namely how i can joint the beams in the nodes that doesn t are joints?
Is there a comand for doing this in the way more simply?
thank you for attention
best regards
samuel
