problems with display of all icons
msoffietti
msoffietti
hello
I work with RSA2016 service pack 3. Robot does not display all icons (see image ). It is same also without service pack.
But when robot is starting, for a little time all icons are visible. When robot has finish its starting operation and I can work, some icons are not  visible....
which is the problem?
thank you
Artur.Kosakowski
Autodesk Support
Autodesk Support
As far as I can see the icons without "pictures" are only these which are not accessible yet because you haven't got any model defined (they should have "pictures" grayed out). I assume thy will be shown correctly if they become accessible as you work progresses. You may also try to switch from best performance mode (which I assume you have set) to best appearance
https://www.youtube.com/watch?v=npdh5qPvH5M
Artur Kosakowski
msoffietti
But this is the first time that I have this "problem". In previus version
all the icon were visible.
michele soffietti
via vanoni, 42
23017 morbegno (so)
Tel/fax 0342-612517
Cell 328-2477617
Attenzione nuovo indirizzo mail: michele@soffietti.eu
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Michele,
As Robot UI has not been changed (is exactly the same in 2016 and previous versions) this would suggest that either you weren't using the best model or OS or/and graphic card behaviour might have been different comparing to your current computer.  We will investigate if this can be improved.
Artur Kosakowski
