Example not specified
skilak
skilak
Any logical explanation of this error - Example not specified?
Best regards,
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you atatch the file please? Thank you.
Artur Kosakowski
skilak
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please make sure you set the correct privileges to download the file as I cannot access it.
Artur Kosakowski
skilak
skilak
I have solved the issue, namely the buckling deformation was left ticked after I finished the buckling checks with initial deformation.
Cheers,
