Problems whit integration of RSA folder to Revit
Message 1 of 12
When I try to integrate my folder RSA in Revit, my computer shut down. Can you do the integration for me?
Thank you very much
Olivier , Cegep limoilou student
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Here you are.
Artur Kosakowski
Message 3 of 12
Hi, I see what you did to my friend and I get the same problem if your able to help me it will be very appreciate!!
Thank you very much your help is very usefull 🙂
Message 4 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 5 of 12
I think we all have the same problem! Is it possible to help me too? RSA to Revit
Message 6 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 7 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
The initial investigation we have made indicates that the issue is cased by rigid links not being correctly handled when Robot has got French interface. The workaround is to:
1. Change Robot interface language to English
2. Export model from Robot to Revit
3. Change Robot language back to French
Artur Kosakowski
Message 8 of 12
It still doesnt work for me... can you do it please? 🙂
Message 9 of 12
Can you help me to integrate my folder RSA in Revit please. I have the same problem than my friends
Message 10 of 12
Message 11 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is it the same model as in http://forums.autodesk.com/t5/robot-structural-analysis/integration-robot-to-revit/td-p/6240327 ?
Artur Kosakowski
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Here you are.
Artur Kosakowski
