Problems on Soil Spring Calculator
I am now designing a seawall structure.
In the Robot model, I used the "foundation elasticity calculator" in thickness setting to assign the soil spring on a vertical wall supported by the reclamation soil. I expect the reclamation soil will support the caisson when there is a wave, therefore I assign a soil spring without uplift resistance.
The problem is that I don't know how to use this calculator to calculate the soil in parallel (see picture).
My questions are:
1. Shall I calculate the 3 layer separately in the calculator? Because the calculator can only consider soil in series.
2. What "Dimensions" shall I use for the calculation? Shall I just use the contact area of the particular soil for the calculation? Or shall I just the area of the whole wall?
Thank you.
Rafacascudo
I never used it , but the soil spring is perpendicular to the thickness surface . So I guess you will have to divide your wall according to the number of different soils you have and then enter the appropriate values for each wall thickness piece
Rafael Medeiros
Thank you for your reply.
My biggest concern is that I am not sure about what dimension should I use.
For example my soil layer 1 has 3m depth, if I input the dimension as 3m * width, then I will get a very large stiffness comparing to other layers of soil. The difference of stiffness is now mainly controlled by the soil depth while I think it cannot reflect the real case. That's why I tried to input the foundation dimension as the sum of 3 soil layers, but I do not have confidence on this method.
I would like to know how RSA use this foundation dimension for its calculation.
