Problems applying properties to modified objects
jonathan_leddy
jonathan_leddy
I am modelling a hopper type structure and have created the shape by creating a circle object and then by using substructure modification I have extruded and scaled it to create the shape as shown. I now am trying to apply a 400mm thick wall to this but I cannot get the property to attach to the panel.
Any Ideas?
Many thanks,
Jonathan
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
jonathan_leddy
Hi Rafal,
Thanks for your video. Unfortunately this doesn't quite solve the problem.
If I use the cone option under the objects tab it combines the sides and base as a single element. From what I can tell I can't change these properties independantly from each other and I can't remove say the base/roof of the cone and leave the walls (sides) only?
Is it not possible to apply properties to elements that are created using the substructure modification? I can successfully create the profile using revolve tools but in terms of applying the properties and meshing the slab I am not sure how this is best done.
I decided to play around turned on the "Mark with colours/thickness - legend by colours" The slab now highlights in green indicating that a 200 thk element has been applied....but there is nothing in the properties dialogue to confirm this (see images attached). I ran an analysis and it successfully completed implying that the property was correctly applied, and when I check the base pressure plot it confirms that this property is applied.
I'm thinking that this is a graphical issue with the software?
Many thanks,
Jonathan
Rafal.Gaweda
Autodesk Support
Autodesk Support
If i understood you correctly:
or
If not - make a sketch to show us what you would like to achieve
Rafal Gaweda
