Problem with Russian language - ??? in tables
Romanich
Mentor Mentor
Romanich
Hi again,
This problem have common roots with this and this, but in this case problem very serious.
For example, I have several panels, selected them and copied list "2до6" to the clipboard. After then paste this data for Load table (for example) and obtain this:
After pressing Enter, only panels 1, 2 and 6 will be loaded. Please, watch the video.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi Roman,
please try to change active keyboard to Russian one:russian_keyb.png
In my case it helped.
Nevetheless this effect is under investigation to be explained and corrected :).
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Romanich
Hi Pawel,
Your trick is working Smiley Wink
Roman Zhelezniak
Dear support team,
Could you provide a proper solution for this issue? "tricks" are not working in our case. Thank you.Russian language.jpg
Guys, could you reply if this is solvable or not so we would not waste any more our time.
Thank you.
Pawel.Pulak
Autodesk Support
Autodesk Support
It is not written in which version you observe these effects and the resolution of screen capture makes it difficult to read but I guess this time it is not related to any "tricks" but to standard behaviour of Robot in all versions up to 2013.
All these versions of Robot are non-Unicode so to correctly display non-Unicode caracters (including Cyrillic ones) it is necessary to select appropriate language in regional settings of Windows:
Note: after this change Windows is restarted.
BTW:
Starting from 2014 release RSA supports Unicode so none of above settings or "tricks" is necessary!
Pawel Pulak
Thanks! it is good to know
