- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Team and Users. I have here a problem with loading manual combinations. Model contains 3d steel framed multi-storey building with composite floors. There are many instabilities, "no convergence of nonlinear problem (Link didnt help). I cut on time of calculations, 13h with freezing to ~20min. I dont know if the composite floor works fixed-fixed with beams and columns. I want to compare fixed steel frame to another model-stell tube-in-tube structure, fixed-fixed between composite floors - columns in terms of a bim abilities project, costs, time. Grouped live loads in automatic combinations-manual mode cause a big freeze to my pc with no effects. I assume to change profiles for beams and columns after mes calculation floor after floor. A the main character of "hannibal" says: This is my design" DOWNLOAD. If you have ever seen the solution, which I did not find at this forum yet, just bring it please. Best regards, Bartek
