Problem in deleting nodes
adrian-om
adrian-om
I am having problem in deleting these nodes. I have deleted the whole mesh and try to delete the nodes separately, but no luck. Can you give me a hand with it?
When I try to run the model, it gives me incoherence of mesh as per those nodes.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @adrian-om
It should be enough to select them and use Edit > Delete commands. If this doesn't work could you attach the model?
Artur Kosakowski
adrian-om
I have tried that many times but I cannot delete them.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @adrian-om
1. Open the file in the repair mode following this article
2. Run model verification and click on the isolated nodes warning
3. Open them in a new window and press the Delete button
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
adrian-om
@Artur.Kosakowski
I am getting a bit stuck with the reactions of this model.
I have modelled the slab a a really thin as the distribution of forces should be based in regards to the walls instead of how stiff the slab is. But when I am checking the reactions by hand and the reactions I get from the model, they are not the same... (pretty far away) In fact I got a warning saying that the load wasn't distributed on the slabs, but the reactions are quiet big even if they are not the one I am expecting
Can you have a look into it? I don't know why the load is not distributed, I haven't released the walls in every core as I was trying to see if it works and it is only released in one of them.
