- Mute
- Permalink
- Report
hi
i am new robot user and i have some problems trying to aanalyse a simple bar.here is the case:
i have a simple bar with two suports.one end is pinned (x and z ) and the other end is supported by a roller(there is a x axis freedom and restrained in the z axis ).also a uniform load is presented.
the problem is that after calculations i do not see any x axis movement at the roller support end.even if i input an extreme load the xx displacement at the roller is 0,0
.i see the bar deformed but no movement at the roller.
another strange situation i have if i convert bothsupports to pinned in both axes x and z. i would expect an Fx reaction in the supports as the bar bents downwards but i get 0.0 again.
what am i doing wrong?
can someone please help?
