Hi Artur,
I try another way to simulate a 15m x 12m non-suspended RC slab on the ground. When the nodes within the slab are assigned with Kz for soil elasticity, an error message was notice - no convergence of non linear problem (please see attached snip).
Can you please go through my file and identify why the errors occurred?
Thanks & regards,
Theophilus
Solved by Krzysztof_Wasik. Go to Solution.
Hi @Krzysztof_Wasik ,
I have tried the ways from the recommended page as suggested you. However, it does not work. Can you please have a look on my model and suggest relevant improvements to the model?
The intention of the model is to simulate the behavior of the cast-on-ground RC slab under static and moving loads.
Thanks & regards,
Theophilus
Hi @Anonymous
I have checked your file (last attached version). For cases 1 and 2 (active cases). Matrix update after each iteration is not checked. So it seems that you have not applied suggested solution.
When I will check this option on model converges.
