Principal Coordinate System
Mouhammad_mazzaz
Message 1 of 9
Mouhammad_mazzaz
Hi
I need help regarding to Principal Results what is M1 M2 M12 ?
how can I know the color or how to show the Principal axis ?
Best Regards
Replies (8)
Message 2 of 9
Stephane.kapetanovic
hi @Mouhammad_mazzaz
Could you be more precise ?
is this the IRobotFeResultPrincipal interface?
The local axes of bars have the same color as the global ones.
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 9
Mouhammad_mazzaz
Hi  Stephane ,
Thank for your reply,
Please find the attached photo  https://www.screencast.com/t/RRvgtji8q , here we have 1,2 and 12 , what they meant by M1 is that mean the moment about the local axis 1 ?
As I know that the local axis in robot has the same name of the global axis x,y and z  please see the attached photo
https://www.screencast.com/t/NZkRSpnZD
so what is the difference between MX and M1 ?
what is the color code of the axis 1, 2  ?
thanks in advance
Message 4 of 9
http://docs.autodesk.com/RSAPRO/2014/ENU/index.html?url=filesROBOT/GUID-E73EA3A2-AEC8-40EA-8AC3-E7ED...
Message 5 of 9
Mouhammad_mazzaz
Thanks again
but I did not find my answer there !!
I need to know what the M1 M2 M12 means ??
is 1 or 2 is a local axis ?! how to know the direction of these local axis
the link that you post has the direction of the local axis x,y,z
did you understand my question ?
Message 6 of 9
https://knowledge.autodesk.com/support/robot-structural-analysis-professional/getting-started/caas/C...
Message 7 of 9
Mouhammad_mazzaz
Thank you for the references
Message 8 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Mouhammad_mazzaz
You can see directions (trajectories) of principal moments M1 and M2 by presenting crosses.
Krzysztof Wasik
Message 9 of 9
Mouhammad_mazzaz
Thank you , you saved me
