Floor load
Floor load
marijapoljak
Message 1 of 9
Floor load
marijapoljak
Hallo everyone,
I need to add uniform loads during the area, bounded by nodes 280-281-282-283, and ste second one on the rest of the floor area. The force is in kN/m2. How to do that? The structure is container.
Replies (8)
Message 2 of 9
Stephane.kapetanovic
hi @marijapoljak
you can create cladding and apply area loads. The surface loads are distributed according to the span direction and the selected or excluded elements.
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 9
marijapoljak
Thank you,
now I have this warning. How to fix it?
Best regards
Message 4 of 9
hi @marijapoljak
Go to load distribution, and apply a type (one or two way)
Best regards
Message 5 of 9
marijapoljak
It works. Thank you 😀
Message 6 of 9
TdelaconchaHCUVM
Hi there,
Good responses.
I do have a question though. If I have a horizontal X brace on that floor, how do avoid it being loaded by the cladding?
Thanks in advance
Tony
Message 7 of 9
Simau
@TdelaconchaHCUVM
Select all braces and in the object inspector tick  the arrow in analyse then "ignore"
M. Agayr
Message 8 of 9
TdelaconchaHCUVM
Thank you for your reply. So if I click ignore on analyse, then they will not function as intended to provide lateral stability, no?
Message 9 of 9
Simau
@TdelaconchaHCUVM
No," ignore" means that claddings will not transfer loads to selected beams.
Bracings will obviously fonction as intended
M. Agayr
