Precast Hollow-Core Slab
Would you learn me how to model one way slab as hollow core slab and its stiffness to be represented in the model.
Please share tutorials, video and steps.
Rafacascudo
model the slab with moment linear releases on the edges and use this type of thickness
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to check if the suggestion posted by @Rafacascudo answered your question? If yes, do you mind marking his post as the solution so that it is easier to find by others? Thank you.
Artur Kosakowski
