Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Potential bug with NP EN 1998 spectra
1 REPLY 1
brisid.isufi
122 Views, 1 Reply
I am using the NP EN 1998-1 spectra in my model, but I noticed that the results do not match my hand calculations. So, I decided to run a spectral analysis in which I define the spectrum manually and the results now match my hand calculations. I might have made a mistake somewhere, but I checked several times and this does look like a bug to me. Could someone please take a closer look? I will provide more details below.
This is my model:
and these are the loads:
This is how I applied seismic loading:
Then I built the code spectrum on my own for comparison:
When I run the analysis, I get these shear forces for the automatic spectrum:
and these for the manually defined spectrum:
The sum of shear forces from the manually defined spectrum matches my hand calculations pretty closely:
Is there a way I could see the automatically defined spectrum? Could someone please look into this? I am attaching my model.
Thanks!
1 REPLY 1
brisid.isufi
in reply to: brisid.isufi
I am sorry, I was wrong and I found my error. It had to do with the importance class. I was using Importance Class I while thinking of Importance Class II.
I also found out how to see the response spectrum: Analysis - Calculation Notes.
